Transmission Hot Issue
Hunt&Fisherator
If its doing it with several different transmissions Id say you damaged your harness when the first bell housing broke. Inspect the harness for a pinched or damaged wire. Fluid inside the harness will sometimes cause some weird **** too. I would get under it and ohm your circuits to see what's affected and go from there before I spent another dime. Most likely you were pulling transmissions that weren't hurt.
Has the pump been replaced since the first incident?
Another thing Id consider is putting a manual temp gauge in the cooler line somewhere to rule out an electrical issue there.
I got my AEM Gauge hooked up to the pressure port on the Trans to read the temps
But the weird thing is that at some points when it shows hot It's only ~160-170F,
zblee
63
06-10-2023 01:25 PM
LCHEE
10-24-2020 04:10 PM
superchomper2003
08-26-2015 09:39 AM
ullose272
11
07-17-2015 07:22 AM
