transmission hot message
Old 06-24-2010, 10:12 PM
bad cutt's Avatar
Default transmission hot message
I just got my new trans this week. 03 sierra k 1500. it has a 5.3 with a front mount turbo. i never had the trans getting hot before. i have a 3400 stall. it only seems to get hot when i get on back roads where i am on and off the throttle. i installed a new cooler with the trans. it didnt do this with the pevious transmissions. any ideas?
Old 06-24-2010, 10:57 PM
I have a gauge for that
Atomic's Avatar
What kind of cooler do you have? I believe that message is triggered at around the 280 degree mark, and at that temp your trans is not going to last very long. Does the torque converter ever lockup?
Old 06-25-2010, 08:15 AM
bad cutt's Avatar
Its a hayden cooler. the one that came with the new performabuilt trans and yes it locks up like it always had. i am going to check the cooler flow this afternoon. i am wondering if the converter s causing heat
Old 06-25-2010, 09:13 AM
Atomic's Avatar
Higher stall converters definitely cause more heat, but it sounds like the cooler line is clogged or something. It should never get that hot.
Old 06-25-2010, 11:09 AM
stevenc's Avatar
if a cooler line is clogged, I would get it fixed asap because you could be starving your planetary of lube.
Old 06-25-2010, 02:55 PM
dhpro's Avatar
EXACTLY the same thing happened to me...I ended up replacing my cooler and discovered a kinked line. Make sure its good good airflow as well...tune also plays a part regarding shift points and lockup, but u seem to have that under control. I'd suggest changing fluid if u drove it too far after the msg...u can tell if the fluid burnt. R/
Old 06-25-2010, 06:10 PM
PT's Slowest Truck
budhayes3's Avatar
Definitely get it fixed ASAP and don't drive it until you do! Check all the cooler lines for kinks, and make sure that they aren't laying against the headers...
Old 06-25-2010, 07:10 PM
dhpro's Avatar
I got money on kinked/clogged line...dont **** around have someone who knows their **** look at it...its cheaper than rebuilding a burnt tranny and TC - I've done that too!!!!
Old 06-27-2010, 10:09 AM
HoveyBayou's Avatar
Are you bypassing the radiator?
Old 06-28-2010, 07:18 AM
built408's Avatar
Message comes on at 262 degrees, definitely not good for a trans.
Quick Reply: transmission hot message
