Transmission info display very dim after 80 swap
Finished the 80 swap in my 03 silverado.
Upon starting it I noticed that the Trans info display was a lot dimmer than before. Here is what it looks like if you look closely you'll see it's in reverse
Before the swap the display was as bright as the odometer display..
Any tips or suggestions?
I heated it to make all the glue soft enough to let me plug the main harness back into the mlps. I will review the plug and see what I find
They do make replacement ends for repairs like this as well. In the future a hair dryer, heat gun or an old fashion drop light with a regular old bulb work well for heating this connection up for easier removal. I use to take my drop light and hang it right on the switch when I started removing the dive shafts and other stuff. After about 20 minutes the plugs would come out pretty easy and never had an issue.
gtyler04
07-28-2015 06:21 PM
Nimoryan
07-05-2015 03:50 PM
