transmission pro's enter
i have often wondered this. the old saying "don't spray through a shift on a stock trans" how much of this actually holds any truth. turbo, blower, whatever other forms of forced induction you don't lift, can produce as much torque, but you don't lift on those, why just the bottle?
am i missing something here?
How large of a shot are you talking about? Dry or wet? 150 or less with a good trans, I'd spray through the shifts, if everything was setup correctly. Problem with a wet shot is that the PCM/TCM doesn't know about the extra power being generated, so the line pressure on the trans won't be as high as it should (this is accounted for with a dry shot, or forced induction, since the MAF reads the additional air mass). This needs to be accounted for in the tune.
zblee
11-11-2015 12:41 AM
bluestang50
09-21-2015 08:36 AM
