Transmission removal questions - 2002 Z71
Old 01-28-2014 | 02:26 PM
  #21
rel3rd's Avatar
11 Second Club
Originally Posted by oldred95
For what it's worth you can get the rear main seal housing which doubles as the rear engine cover, with seal installed, a new gasket and new bolts from GM cheaper then you can get just the gasket and seal. I've seen the gasket leak more then I have the rear seal.
Definitely the way I think I should go. Thanks for the info.
Originally Posted by Chevy_King1500
have Mangled help you, buy a 30 pack and im sure he'd come over
Good idea.
Originally Posted by Atomic
Pretty much, last time I did it I had it out in 2 hours flat. I recommend disconnecting the tcase so you can drop and install that separately.
No ****....got a part number?
Yessir, a part # would surely help. My local Chevy parts guy lacks in the parts finding skillset, lol.
Old 01-28-2014 | 03:13 PM
  #22
GREENSIERRA's Avatar
I just dropped my trans in an hour and a half by myself on the ground yesterday. I have tried with tcase on and off and find it easier taking the tcase off. its a lot quicker to drop the tcase then to take the keys and bars out.
like mentioned don't forget that you have 2 bolts that will have 13mm holding the dipstick on and then another holding fuel lines I think it is. once you have those off you can get to the 15mm bolts. your bellhousing might take some convincing to separate from the block tho
Old 01-29-2014 | 11:38 AM
  #23
rel3rd's Avatar
11 Second Club
Question
I think this is the "kit" you guys are talking about?
DORMAN Part # 635518
$34.79 @ Rock Auto.
Old 02-08-2014 | 06:45 PM
  #24
Mark Buck's Avatar
Removing the torsion bars is a lot of extra work plus you have to separate the transmission and t case at some point might as well do it in the car. secondly the allen headed torque converter bolts went away in 01 and there is a GM bulletin stating to replace them with a standard bolt I use to do a ton of them when I was at the dealer. the part number has changed a few times and I don't have the new number. As far as the rear main seal, housing and gasket buy GM. I would change the seal and gasket, do not see the need to replaced housing. I personally have never seen one leak on a LS motor.
zblee
63
06-10-2023 02:25 PM
USMCvet0311
08-01-2015 08:45 AM
LoneSStar
07-27-2015 10:27 PM
bsgiffor
07-19-2015 12:14 PM
