transmission wows
14 Second Truck Club
transmission wows
Hey guys need some help ASAP! My truck is down....symptoms: no movement in D, no start from a stop in 3, manual 1 and 2 and R work great, can manually shift into 3rd once up to speed but once stopped no movement just "neutral". got a code for solenoid b malfunction. I'm in need of ideas as i'm too frustrated to mess with it anymore.
truck is a 2000 rclb 2wd 5.3 4l60 fluid isnt burnt and no clutch residue in pan. has alto red clutches throughout, beast sunshell, vette servo, hd-2, tb stall, new wiring and shift solenoids. It worked excellent for 4 weeks and now this..
Thanks for any help guys
Any idea on possible causes? lack of lubrication, too many shims in the hd-2, incorrect installation? i'm in a battle with time and dont know if i should tear it down replace the seals and gaskets and whats broken and go on my way or if i should just take it somewhere.
formerly 1BADC10 (12/14/2011)
I've had that issue TWICE. Stock sprags suck! They don't like taking hard shifts. The BW setup has taken a few high rpm dumps into gear after waiting on the fluid pressure to catch up. Vac mod helped avoid that.
BTW, if this is a DD, I'd take the washers from the HD2 out of the trans (unless race firm shifts are what ya want).
calsdad
06-14-2023 11:07 PM
jscherbs
09-30-2015 07:54 AM
