trany fluid change?
I would stick with the factory oil for that transmission. The idea with the oils used now a days is that they do not need to be changed as often. However changing them early is not going to hurt. I would probably do it every 25k or do them per the factory recommendations. Obviously in a HD or HP application you should service regularly. Not an exact answer but advise for you to consider. HTH Vince
Suburban2500
07-19-2015 04:50 PM
