Tru-cool 40k is on!!
Old 05-22-2010 | 12:07 AM
Jeteys5.3's Avatar
Default Tru-cool 40k is on!!
However i have a question. There was not much fluid that came out of the stock cooler, maybe because the truck had sat all day. As in maybe 8oz came out, around enough to fill a small glass perhaps. Started up the truck and checked the fluid and it was still in the normal area. But i know this cooler will hold more, alot more, so do i need to add any? Or just let it run for awhile longer as in take a trip to the store then check it? or am i fine until tuesday when the stall goes in and fluid changed?
Old 05-22-2010 | 01:37 AM
bud8fan's Avatar
as long as it stays around the full mark you will be fine till the verter swap
Old 05-22-2010 | 02:12 AM
Dewey's Avatar
yup just keep an eye on it, because it may take a little bit of time for that cooler to fill up.
Old 05-22-2010 | 03:29 AM
1LOW4X4's Avatar
Banned
I drove mine a lil while and had to add like a lil more than half a quart.
Old 05-22-2010 | 08:45 AM
dewmanshu's Avatar
Moderately Differentiated
Yeppers, let it run for a bit and keep checking the level. It should drop eventually if not pretty quick IMO.
Don't forget to give extra fluid to your trans guy.
Old 05-23-2010 | 12:11 PM
Pooki's Avatar
Were are you guys buying your Tru-cool 40k from? I live in Canada and would like to pic one up.
D1SCSS
07-25-2024 07:54 PM
SlvrSierra4.8
10-01-2015 10:39 PM
slowlsx
08-10-2015 06:33 PM
Dirtywhite
08-05-2015 05:10 PM
Ls3silverado
07-31-2015 05:22 PM
