true trac and 4.30s
true trac and 4.30s
Well my rearend is about to explode in my truck and i guess its the best time to go ahead and put gears infront and rear while im at it.. Im gunna run 4.30s and a true trac in the rear.. wheres the best place to pick up a true trac with the best pricing ? btw its a half ton truck 10bolt rear and i need gears for the front diff too what would be the best gears to go with ? and place to get em?
thanx,
Garrett
thanx,
Garrett
https://www.performancetrucks.net/fo...ight=gears+ron
I can't find any 4.30s on his site tho. Just 4.11 and 4.56
http://cgi.ebay.com/ebaymotors/GM-8-...Q5fAccessories
And these are one that come with a tru trac like posi and gears
http://cgi.ebay.com/ebaymotors/GM-CH...Q5fAccessories
Tru Trac
Motive 4:11
Motive 4:56
Tru Trac
Motive 4:11
Motive 4:56
Where's the Beef?
As i've stated in every thread asking this question.
Rons Machining Services on Ebay.
Motive Gears don't whine
rear as you stated is 10 bolt 8.5/8.6
Fronts I don't know. If you call Rons he can help further.
What makes you think your rearend is about to explode? Spiders making noises?
the the g80 is locked to the left and will not unlock... with just normal driving no spinning its staying locked up and the whole freakin truck shakes when turning to the left.... and it has 140k on it
