Trutrac driveway install questions
I just took a punt and used the same shims. Worked out spot on. (yes I used a dial indicator and the paste to check everything).
Hang on...yours has the shims 'under' the bearings?
Mine were on the outside.
If the shims go on the outside then I am set. I thought they went on the inside after reading some how to articles showing how to make set-up bearings so you don't have to press them on and off to check tolerances. Thanks Howard.
First off, new bearings come with an install kit but theres no need to get an install kit unless you're installing a new ring and pinion. I would check out the truetrac website and see what bearings it calls for...Get those pressed on at a local shop. It costed me $10 to have both carrier bearings pressed on. I ordered a pack of shims and ring gear paste from summit. I bought a cheap dial indicator from harbor freight as well. I swapped my rear end and luckily, the backlash was perfect with the factory shims. Also, i didnt use new ring gear bolts. Just remember, those bolts are threaded in reverse direction. Right=loosen. It's not hard! Goodluck.
I bought new ring and pinion because mine lost teeth in the destruction of the G80. The R & P came with new bolts as well as the crush spacer. A good tip with this was to use a press and crush the spacer maybe 1mm (just until it starts to move/crush (you can tell by the stress line that appears around it). Under the car you'll need a piece of pipe maybe 3ft long on the end of the pinion nut to crush it as you do it up. You need to pull it up gently and keep checking the backlash as you go. If you crush it too much...you'll have to start again.
I built a spreader also...but didn't end up needing it.
Hmmm..sorry can't remember. Pretty sure they're a LH thread though.
EDIT: didn't need to spread the case. I was able to tap the shims into place with the diff at the same time.
