turbo 400
#22
Originally Posted by whitt1
Rossler makes a trans brake for a 4L80E.It's on their web site.The only down side for the 4L80E is the tall 2.48 first gear,but it offers closer gear spacing with a 1.48 second 1.0 third and a .75 fourth.
A T56 is almost 20 year technology. A PG is an even older design than a TH350/400 but obviously the guys that run those are slow and they don't know what they're doing either.
![Rolleyes](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/rolleyes.gif)
#23
5 year bitches!
Originally Posted by vanillagorilla
Did you check the price tag on that? You might want make sure you're sitting down.
A T56 is almost 20 year technology. A PG is an even older design than a TH350/400 but obviously the guys that run those are slow and they don't know what they're doing either.![Rolleyes](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/rolleyes.gif)
and stock PG are junk, its when you build them, stock 350/400 are junk unless you build them, 60/80 are junk unless you build them can y ousee a pattern? all stock trans are junk...its when you build them when they are strong
#24
I assumed we were only talking built transmissions here. Stock trannys in a performance truck is like oil and water.
There are plenty of cars that have PG's on the street even in the most extreme form. In a heavy truck no, but street/strip cars live with them even with 5000rpm stalls.
You're forgeting two things when determining transmission streetability and gearing, and that's rear end ratio and tire diameter.
Crunch the numbers: TH400, 1:1 3rd gear with a 31.9" tire and 3.08's vs. T56 .5:1 6th gear with a 28" tire and 4.88's. Not too much difference regarding cruise speeds. Turbo's like high gears, so going with a 3.08 with a 1:1 3rd gear makes it work for me. It's equivalent to having an 80E with 4.10's which is what a lot of people run around here with less parastic drag, less weight, ability to shift myself and have a transbrake. Not to mention the TC choices and the availability and cost of replacement parts.
You can get almost any set of gear ratios too for a TH400 from John Kilgore.
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
#25
5 year bitches!
You can get almost any set of gear ratios too for a TH400 from John Kilgore.![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
from my experience with 400/80 you need gearing but im also around NA applications for most part
but for you best of luck
#26
![The Judge](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_judge.gif)
Originally Posted by Quik
for you is one thing for DCracer is another. and if you were comparing to me i run on 30" tall tires on hte street for cruising.
DC? GM lol
