turbo 400
#22
Originally Posted by whitt1
Rossler makes a trans brake for a 4L80E.It's on their web site.The only down side for the 4L80E is the tall 2.48 first gear,but it offers closer gear spacing with a 1.48 second 1.0 third and a .75 fourth.
A T56 is almost 20 year technology. A PG is an even older design than a TH350/400 but obviously the guys that run those are slow and they don't know what they're doing either.
#23
5 year bitches!
Originally Posted by vanillagorilla
Did you check the price tag on that? You might want make sure you're sitting down.
and stock PG are junk, its when you build them, stock 350/400 are junk unless you build them, 60/80 are junk unless you build them can y ousee a pattern? all stock trans are junk...its when you build them when they are strong
#24
I assumed we were only talking built transmissions here. Stock trannys in a performance truck is like oil and water.
There are plenty of cars that have PG's on the street even in the most extreme form. In a heavy truck no, but street/strip cars live with them even with 5000rpm stalls.
You're forgeting two things when determining transmission streetability and gearing, and that's rear end ratio and tire diameter.
Crunch the numbers: TH400, 1:1 3rd gear with a 31.9" tire and 3.08's vs. T56 .5:1 6th gear with a 28" tire and 4.88's. Not too much difference regarding cruise speeds. Turbo's like high gears, so going with a 3.08 with a 1:1 3rd gear makes it work for me. It's equivalent to having an 80E with 4.10's which is what a lot of people run around here with less parastic drag, less weight, ability to shift myself and have a transbrake. Not to mention the TC choices and the availability and cost of replacement parts.
You can get almost any set of gear ratios too for a TH400 from John Kilgore.
#25
5 year bitches!
from my experience with 400/80 you need gearing but im also around NA applications for most part
but for you best of luck
#26
Originally Posted by Quik
for you is one thing for DCracer is another. and if you were comparing to me i run on 30" tall tires on hte street for cruising.
DC? GM lol i think the 80e is gonna be best for my setup, i just wish there was a way to get rid of all the aluminum in them... like my 60e has eater 3 pumps now, it sucks... but Im sure the 80e will hold up just fine
