Turning radius Sucks with Mcgaughys spindle.
Originally Posted by Sport Side
Turning radius sucks as is... No thank you to spindles for me.
Which is better in the long run?
TOTM: January 2007
Originally Posted by NeverSatisfied02
Well you cant get a 4" front drop without them unless you use a control arm drop which will give you bumpsteer. I guess both have their downside.
DJM also has a tie rod relocator kit that is said to alleviate the bump steer issue.
Originally Posted by j's01silverado
Bumpsteer is not that bad. If you can live with riding on 40 series tires, I dont think the bump steer will bother you.
lcas have problems being aligned too! bumpsteer is very annoying IMO. if i wanted to feel like i had an old truck, id buy one. get the mcgaughys spindles they are the best and the ride is outstanding.
TOTM: January 2007
I have had my DJM LCA's for 5 years with no un usual tire wear or alignment problems. Not sure where you get that they cant be aligned. Bumpsteer is there, but I dont think its unbearable. If it is, there is a solution.
I would use McGaughy only on a 4wd/AWD/torsion equipped truck. Other than that, it would be LCA's or even coil springs. Cant stand the turning radius.
Adkoonerstrator
Damn, my turning radius sucks like it is stock but, I'd really like to lower the SS two inches or so. I've heard bad about both the BellTech and McGaughys spindle now.
TOTM: January 2007
Did you notcie any turning radius differences with yours?
