Twisted axles splines 10 bolt
Old 06-01-2015 | 03:18 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by GMCtrk
What's the cost of one of those Ford 9" rear ends. Isn't it going to end up being over 3k?
I can get a junkyard 14 bolt with evertything on it and 3.73 or 4.10 gears for $1000-1200. I can sell my current rear end being worth at least $500 (trutrac and AAM 4.10 gears). And I can swap over my rear brakes or just run the 14 bolt drums, both of which would clear 15s.
At this point, it's all about cost to benefit ratio because I'm tired of dumping money into an old truck which is only worth about $4000 based on age and mileage. I just want a 10 second slip and be able to drive home.
Just out of curiosity, would the twisted axle be a reason I could never leave the line without spin after my first ever 1/4 mile pass on the drag radials? That first run it dead hooked 1.63 60' and since that point it could never hook up cleanly.
The dead hook is probably what Twisted it. The spline alone being twisted would not cause a traction issue. Something like A bent axle tube or The pinion setting shifting from a hard launch would affect traction.
The cost of a 9 inch is dependent on the parts you put in it.
The ones I have built for my stuff in the past have been upwards of 3K.
Again it's all dependent on the parts you put in it and what you start with.
Old 06-01-2015 | 04:56 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
go for the bolt in 9 inch imo
Old 06-02-2015 | 08:28 PM
07bluelbz's Avatar
Gmctrk, can you find any 6 lug 14 bolts in your area. All I can find is the Obs ones.
Old 06-02-2015 | 08:33 PM
GMCtrk's Avatar
There are a few listed on car-part.com
Old 06-02-2015 | 08:53 PM
07bluelbz's Avatar
Thanks. I'll check that out.
Old 06-02-2015 | 09:49 PM
gamble686's Avatar
Got torque makes awesome rear ends including a true Boltin 9" with stock brakes and everything.
5.3Okasai
03-09-2022 01:07 PM
Blue03sss
03-07-2019 05:06 PM
FlowmasterMufflers
09-21-2015 01:52 PM
vipergtrdj
08-06-2015 10:19 PM
Dezert1500
07-30-2015 02:51 PM
Quick Reply: Twisted axles splines 10 bolt
