Two piece driveshaft in rcsb
Old 10-22-2009 | 08:01 PM
xrevx1's Avatar
Default Two piece driveshaft in rcsb
Has any body installed a two piece driveshaft in a rcsb? Thinking about trying this because my 4" alum. driveshaft is not working out. Truck is low and rubs on the bottom of the cab. Any input would be great.
Old 10-22-2009 | 08:17 PM
BigCountryx's Avatar
Is it just rubbing a lip or something on the cab that could be trimmed... Maybe you could run a smaller diameter steel shaft that would clear. I wouldn't bother with a two piece on such a short shat if it could be avoided.
Old 10-22-2009 | 08:22 PM
viciousknid's Avatar
Where's the Beef?
A 2 piece is long. just the rear portion is probably as long as your entire shaft. There's plenty of lowered guys on here that could chime in with some tips on what to do.
Old 10-22-2009 | 08:59 PM
xrevx1's Avatar
Trimmed all I can trim truck is on air. I had the 4" alum. built for high speed but I cant put the pinion where it needs to be because it hits.
Old 10-22-2009 | 09:01 PM
RandomHero's Avatar
There are plenty of bagged and body dropped guys that are using their stock driveshaft. Do they not make a steel driveshaft for the regular cabs?
Old 10-22-2009 | 09:04 PM
budhayes3's Avatar
PT's Slowest Truck
I don't see how a 2 piece would fit under a rcsb...I'd think that it would have to be shortened tremendously.
Old 10-22-2009 | 09:05 PM
xrevx1's Avatar
I am thinking about a g8 2 piece driveshaft but I need the lenght of it U joint to U joint.
Old 10-22-2009 | 09:08 PM
Where's the Beef?
Oh. well that makes a difference. What was wrong with the stock shaft?
Old 10-22-2009 | 09:11 PM
xrevx1's Avatar
I have broke 2 steel driveshafts. I need it to be high speed balance.
Old 10-22-2009 | 09:13 PM
Where's the Beef?
ouch. I'm guessing the 4" is larger than a stock shaft? considering that the stock one fit but your aluminum one doesn't? could it be a measurement problem?
Good luck. Hopefully someone on here knows the answer
Quick Reply: Two piece driveshaft in rcsb
