U Joint Help?
Old 08-10-2021 | 05:09 PM
mikerlew's Avatar
Default U Joint Help?
So I am finishing up my rear end rebuild, and I think I know the answer, but a second opinion is great. I accidentally pulled the caps off the rear U Joint on the driveshaft. I put the caps back on, hoping I didn’t mess the needle bearings up. So what I am dealing with is that one tiny needle bearing is stuck on the end of the cap. What I’m wondering is if I can carefully place them back in order and if my U Joint will work fine. If that doesn’t work, I’ll replace the U Joint which is near 30$ but that’s an extra trip into town.
I appreciate any help!
Old 08-10-2021 | 06:12 PM
RB04Av's Avatar
Yes, you should be able to do that.
You'll probably have to slide the last one into place alongside the others, endwise; it shouldn't be able to just mash down in among them.
Old 08-11-2021 | 12:25 AM
RedXray's Avatar
100% Redneck
If the needle didn't get crushed yeah line the needles up again and send it
Old 08-11-2021 | 12:28 AM
mikerlew's Avatar
Okay sweet. I have a press if I needed, but I was hoping not to have to do that. I don’t expect it to be crushed, I simply placed it back on and tried to push it with my hand, no hammers or anything. Thanks for the added boost of insight!
Old 08-11-2021 | 12:29 AM
mikerlew's Avatar
Sweet, sounds good. Thanks man. Learning lots of new things with this axle haha
jplowman2005
06-25-2012 02:10 PM
peterls1
01-15-2012 02:14 PM
CashDudeHomie
12-09-2011 12:49 AM
getchusum99
04-30-2011 09:53 AM
KeukaZ71
13
11-25-2004 09:40 AM
