U jount replacement, How to
Old 03-28-2007, 11:32 AM
CHEVRACER83's Avatar
Glad You Got It Goin 1slow....
Yeah If Its Greasable And Your Making A Considerable Amount Of Power... Or Just Beating On It... They Canfail Rather Quickly...
But Those Do Look Good
Old 03-28-2007, 12:04 PM
dan96z71's Avatar
Those things can wear you out trying to beat them out of there. Finished product looks very nice though. Good work!
Old 03-28-2007, 01:53 PM
TOTM: June 2007
bgray's Avatar
Anybody know where I can get Stron ujoint online? WE dont ahve autozone up here in Canada....thnks!
Old 03-28-2007, 02:10 PM
Search For "spicer" Those Are Very Good Ones
Old 03-28-2007, 04:45 PM
Destroyer of Transmissions
1SlowHoe's Avatar
Originally Posted by j's01silverado
Is the new joint sealed? Or greasable?
The greasable u-joints are tapped with zerk fittings and are hollow in the inside making them very weak.
The reason I ask is because a local shop installed a greasable u-joint and I snapped it in just 2 weeks and damaged the driveshaft. Horrible experience and cost me about $400 in repairs for a $20 u-joint.
I have no idea. You had to pull the end caps off to get it in. Inside the cap was a ton of bearing packed in grease so I guess they are greaseable. But if you wanted to grease it, you'd have to take it back out. The silver caps slide off and the red rubber rings stay in place.
Old 03-28-2007, 04:52 PM
No I Dont Think Theyre Greasable.... I Remember When You Sent Me The Pics
Old 03-28-2007, 08:16 PM
truckmann's Avatar
Sounds like they are non-greasable to me. If there is no place to grease them while they are installed that's non-greasable.
Old 03-28-2007, 09:04 PM
1SlowHoe's Avatar
The guy at the counter said it was the strongest one they carried. It was pretty heavy as well. Solid steel/iron...something.
Old 03-28-2007, 10:46 PM
TOTM: January 2007
Last Call's Avatar
Sure sounds like they are sealed. If there is no zerk fitting, which apprently there is not, you are in the clear. Good buy and nice looking driveshaft!
Old 03-28-2007, 10:52 PM
1SlowHoe's Avatar
I wanted it to match the FLT tranny.
Quick Reply: U jount replacement, How to
