vibration after 80mph
Old 11-24-2007 | 07:15 PM
v8
17,16,15,14,13,12,11 Drvr
Default vibration after 80mph
Ok first off hit some wood awhile back and it took out tail housing on trans, drive shaft, since then had all that fixed but the vibration is still there, could it be trans or rearend??
to help some the wood hit right at the rear of the driveshaft, thanks for any help, going to try and find a shop just not sure what kinda shop to look for ahahaa.
Old 11-25-2007 | 10:02 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
I'm gonna post a pic of something when I get back home (in New Orleans right now). Can't say that it's the source of my vibration issue that is noticeable above 85 mph, but certainly something else to check. I need not say have the yoke/pinion angles checked. That's the first thing I'm gonna have checked in about a week or so.
After re-reading your post, are you saying that you've always had vibration issues?
Old 11-25-2007 | 10:18 AM
v8
No the vibration started after the wood hit the driveshaft.
Old 11-25-2007 | 10:45 AM
TXsilverado's Avatar
u and farmerbeau should get together on this one haaha.
Old 11-25-2007 | 04:13 PM
v8
I hear ya tx, yours is next ahhhaa is it apart yet?
Old 11-25-2007 | 04:31 PM
decided to do a before and aftert dyno on the heads so im holding off on pulling it apart.
Old 11-25-2007 | 04:43 PM
v8
Good deal, I can't do that it wont let me go over 80 ahahhaaa
Old 11-25-2007 | 05:49 PM
v8
well took the neighbor for a ride, he thinks its the rearend, got it up to speed and put it in neutral and still was there so will find out tomorrow.
Old 11-25-2007 | 06:58 PM
95ImpSS's Avatar
I never thought to try that. Hmm... At least that'll tell you that vibration could be from the rear up to the planetary (I think). Still a lot to consider though.
Oh... (v8) the reason I asked was because of my interpretation of the first sentence in your first post.
Old 11-25-2007 | 07:07 PM
00Silv4.8's Avatar
u sure the shaft is balanced right and all? maybe even u bent a rim or something hitting that wood if it fucked ur shaft. Maybe check balance on ur wheels 2? possible impact break on the inside wall?
