VSS 4l80
VSS 4l80
I have asked this before but I am still confused about the VSS on the 4l80E swap. I have ONE VSS on my 4wd 4L80 it is in the front of the tranny. There is a plug in the rear hole. Is the front plug where I plug in the new harness? If so what do I do with the old VSS harness from the 4L60 do I just tie it up somewhere? Pics would be great and good details would help!!
How do I change this text
Originally Posted by cablebandit
i would assume the factory plug goes to the vss in the transfer case and the new plug from your new harness goes to the sensor in the fron that you mentioned
That is right.
All the wiring to the T-case stays the same, the harness that you got from speed engineering goes from the ECM plugs into the front sensor on the 80e.
