welding axle tubes?
Old 03-06-2015, 03:04 AM
8 Second Truck Club
natejk's Avatar
Default welding axle tubes?
Can anyone tell me if this is a good or bad idea? Anybody done it ?
Old 03-06-2015, 04:52 PM
iamkeniff's Avatar
A ton of people do it. Most just go 14 bolt swap, but welding yours wont hurt
Old 03-06-2015, 11:24 PM
8 Second Truck Club
natejk's Avatar
Well I'm gonna be doing a c notch and shock relocation so I figured if I was gonna be there I may as well haha
Old 03-07-2015, 01:04 AM
Custm2500's Rude Friend
1FastBrick's Avatar
I weld the center of every housing I work on.
It's a very common practice.
Old 03-07-2015, 02:33 AM
8 Second Truck Club
Blown06's Avatar
If your gonna weld it. Take it completely apart. Weld it. Then take the housing to a rearend shop to have the ends cut off, straightened and welded back on with the proper fixture. If you don't wanna go through that, don't do it. It will warp the damn thing quite a bit.
Old 03-07-2015, 09:48 AM
thewrx's Avatar
I plan on doing it to my 14 bolt along with other mods.
Blown what ends are you refering to?
Old 03-07-2015, 10:00 AM
Formerly ScreamingL
George C....'s Avatar
ive welded a few rears that were together and didnt have warpage or issues later on
make sure to use the correct filler and procedures otherwise it will just crack
Old 03-08-2015, 09:31 PM
8 Second Truck Club
natejk's Avatar
I'm really on the fence about it I don't want to have any issues nor do I want to fully disassemble the thing I've read people use a 7018 rod pre heat it and post heat it and cover with a heat blanket
Old 03-08-2015, 11:53 PM
1FastBrick's Avatar
That Sounds like arc welding rod.
Old 03-09-2015, 12:17 AM
8 Second Truck Club
natejk's Avatar
Apparently a friend of a friend welds axles all the time I've seen his tig work on turbo kits I'm just gonna have him do it
Quick Reply: welding axle tubes?
