Well well isn't this a bi^&H!
Baltimore Whore
Yah they were caltracs, if i did it, they wouldn't have broke.. The rest of ya can hug my sweaty nuts
And the side that broke was the side that the wheels are facing the right way...
Dustin, I check them a decent amount to make sure they have some play in them, not jammed tight.. Ohh well that side is off now, have to order another end tom for it..
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
Baltimore Whore
![Winky](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_wink.gif)
I have a set of stainless ends lined up with teflon washers, all, along with all stainless nuts, bolts and washers I had here at the garage, that will be going in. IMO for that kind of money you should get **** that is all SS.. Just deciding I want to take the brackets and all off, to have them sent out for a REAL POWDER COAT Job, instead of what they say is coated.. I have seen spray paint last longer then the POWDER on these things. I would call and bitch, but would prob get a bunch of BS.. I think I am going to start making these, use stainless hard ware, GOOD coating so it lasts... WHO IS IN???
No based on what they say, you do preload them some, but have to make sure you can still move them by hand. They are not supposed to be loaded so tight that they don't move.. ![Winky](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_wink.gif)
