What 4L60E do I have?
I bought a 4L60E really cheap from a wrecked full-size van.
The van was not present, so I'm not sure what year. How
can I find out more about the tranny?
Some of the tranny markings... 4L60E M30 24204457
It appears to be a 2-piece bellhousing. The bolts to remove
it are accessed from "inside" and not from "outside". FWIW.
I don't think the bellhousing is the exact same as my 4.8 V8.
Is this a Vortec-based 4L60E? If so, can it still work behind
my 4.8 engine? Can I just swap the bellhousing with an LS1
based unit and, if so, will the 4.8/5.3 wiring still work okay?
Originally Posted by performabuilt
This is a vortech based unit and will not fit behind your engine
Actually, I think I might've found a 5-speed anyways while
I was researching the 4L60E... now that's dumb luck.
I was going with a 4L60E since the T56s were pricey and I
could never find a 5-speed forsale when I was looking...
Thanks for the help!
formerly 1BADC10 (12/14/2011)
This is a vortech based unit and will not fit behind your engine , not only is the bell wrong but the input shaft and the pump stator are wrong , Now it could be modified to work if you changed the input shaft, pump stator or assembly and bell from and LS1 type unit.
Take a look at the input shaft (left)... that'll fit to TCs for Vortech vehicles. The input shaft on the right will fit in TCs for LS-based vehicles with the 4.8/5.3/6.0. See the difference b/t the tips of those shafts? The pumps are different. The drums are interchangeable, so you do not need to press the shaft out of the housing. There's a sponsor (--->) that sells those in a 298mm & 300mm input drum assembly.
