What 4l80e converter?
Old 09-22-2024, 12:35 PM
Wolfy1969's Avatar
Default What 4l80e converter?
Hey everyone. Just wondering what converter everyone ids using.
what I have is 2000 Silverado single cab step side, guessing about 4k weight 6.0, flat tops, 799 heads milled .020, sloppy stage 3 cam tbss intake 92mm throttle body, vs racing 78/75 turbo 4l80e. 4:10 rear gear 29.5 rear tire.
im sure I left something out.
i forgot. It’s a street truck that will see some track. Goal would be a drag n drive type deal
thanks
Old 09-22-2024, 02:11 PM
wretched73's Avatar
Circle D is a popular choice. I'd call them and ask what they'd recommend
Wolfy1969 (09-22-2024)
Old 09-22-2024, 03:25 PM
smokinlmm's Avatar
Between a 2850 and a 3200 depending on how much street driving you do.
Old 09-22-2024, 04:09 PM
Wolfy1969's Avatar
I filled out the sheet. Waiting on reply. I just figured maybe someone has gad good luck with something already.
Old 09-22-2024, 09:34 PM
1redta's Avatar
I put the Summit 4l60e converter 2600-2800? in my crew cab 08 with a 6.0 243/799 BTR truck stage 2 and love it after I broke the 3.73 and put a 3.42 in which tightened the converter up alot
Old 09-23-2024, 08:03 PM
terravast4's Avatar
Definitely Circle D. Tripple disc. They will spec the correct stall based on your specs.
Old 09-23-2024, 08:28 PM
Wolfy1969's Avatar
yeah I got the quote today. 1100 for the converter and 400 for the recommended flex plate.
I am not made of money.
Old Yesterday, 03:41 PM
Wolfy1969's Avatar
ordered the converter from circle d. Did not order the flex plate. Thanks for the info guys
Old Yesterday, 06:16 PM
smokinlmm's Avatar
What converter you go with?
Old Yesterday, 07:40 PM
Fullpower's Avatar
Which size (diameter ) did Circle D suggest ?
Did you get the triple disc clutch ?
Quick Reply: What 4l80e converter?
