What is acceptable TCC slip while locked in 4th under a heavy load?
Old 09-29-2012 | 10:40 PM
03sierraslt's Avatar
I get no slip at all when locked up in OD, even if I build some boost.
Old 09-29-2012 | 10:43 PM
zeake's Avatar
If your converter is a circle d I bet he will stand behind it. The only other than circle d I would have is Precision Industries.
Old 09-29-2012 | 10:46 PM
BlackGMC's Avatar
Resident Retard
Yeah i not blaming circled on this. It could be tuning, my tranny or just a fluke that caused the failure. I am just pissed cause it happened.
Old 09-29-2012 | 10:53 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Remember the filter you cloged early on???
I would say that plus the posibilty of the tuning may have led to an early demise....
Hard to say untill it's cut open.
Old 09-29-2012 | 10:54 PM
BlackGMC's Avatar
Resident Retard
Yep. I will be the first to blame myself. After all it was installed in a tranny i built myself
Yeah when i clogged that filter i wondered what came apart
Old 09-29-2012 | 10:59 PM
1FastBrick's Avatar
Unfortunitaly It's expensive to learn a lesson this way. We have all done it...
I would flush the trans, install a new filter and then tear the converter out for a rebuild. You want to get as much of that stuff out as posible before Installing a fresh unit.
Old 09-29-2012 | 11:02 PM
BlackGMC's Avatar
Resident Retard
Yep i swapped the filter and 6 quarts yesterday. Gonna do it again prior to putting in a new TC.
MikeD.
09-17-2015 10:39 PM
fortune46x
09-16-2015 09:18 AM
Lthompson
09-15-2015 08:55 PM
iregret
09-07-2015 02:20 PM
SWINGRRRR
09-03-2015 08:49 PM
Quick Reply: What is acceptable TCC slip while locked in 4th under a heavy load?
