what gears?
Im on the same mission of changing gears the local shop guy i talked to said that only going up one stage you wont notice much of a difference for the money your spending but since i already have 3.73 any bigger than 4.10s would be way to much since i have stock tires i would never get traction but from what everyone has told 4.10 are a great choice so next week after my headers are installed then go in the gears best of luck to you my friend
I was thinkin about 4.10s but I travel too much to lose that much mpg. I will probably go with 4.10s when I get out of college. I was thinking about richmonds as well. Where is the most cost effective place to buy these?
Dude....4.10's for sure with a large tire combo that you have. I use Richmond in mine. But Yukon Gear is a damn fine gear!!
PM me and I'll give you a phone number of the cheapest deal in the Nation. They aren't a sponsor so I can't post it.
Ck out Randy's Ring and Pinion. Stick w/ a set of AAM (OEM) gears, dead quiet and every bit as strong as the Richmonds. With the 22's a set of 4.10's will be the equivalent of 3.73's w/ a stock diameter wheel/tire
