What in the hell is this hose?
It is the vent for the tranny, that part goes to nothing (well, the bracket should bolt to one of the bell housing bolt studs but thats it), it should go down to a y with a smaller hose coming off if it that slides over the vent tube coming out of the back of your tranny and then some times there is another pieces off hose that goes down and is just open at the bottom of it to let that one drain if it need to, should the tranny puke out the vent. It's not really a necessary part.
It is the vent for the tranny, that part goes to nothing (well, the bracket should bolt to one of the bell housing bolt studs but thats it), it should go down to a y with a smaller hose coming off if it that slides over the vent tube coming out of the back of your tranny and then some times there is another pieces off holes that goes down and is just open at the bottom of it to let that one drain if it need to, should the tranny puke out the vent. It's not really a necessary part.
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
Looks like it will stay off of the truck. Those bell housing bolts are a bitch without the right tools.
Thanks man.
Baltimore Whore
Yup it is the trans vent tube, I took my **** off too, i wasn't going threw the bs of pulling a bolt back out to put it on, I cut it short, tied it abovee the trans case....
John
John
