What are the limits of the 4L65E?
#31
in the world of the 60/65E i figure rossler to the the king and i'd say chuck at FLP is working hard on catching their numbers. 700hp in front of a 60/65E might be done in a 3200LB vehicle, but in a truck at well over 4,000lbs failure will come on a regular basis.
#32
12 Second Club
Originally Posted by PappyDan
I asked about this at a trany shop in baytown, he told me that he could turn my 60e in to a 65e and with a few after market parts it would handle 700 hp with no problem.
the parts would be the most expensive, a sun shell called the beast, a harden shaft, and some type of clutch pack with servos, take out, rebuild, and install would cost about 2000
* Borg/Warner Low Roller Clutch
* New Bushings
* GM Internal Wiring Harness
* GM Solenoids & Switches
* Gm 5 Pinion Front & Rear Planet Assemblies
* Seals, Gaskets, Filter
* High Performance Output Pump Slide Spring
* Borg/Warner 29 Element Forward Sprag
* Steelx.500 Boost valve
* Wide Red Band, Performance Lining
* "Z" Pack- 15 Element 3-4 Clutches High Performance Application
* "Beast" Heavy Duty Shell w/ Bearings & Wide Bushing in Reaction Gear*
* HP Forward & Overun Clutches
* Borg Warner Low Reverse Clutches
* TransGo HD-2 Shift Kit
* Corvette Servo
* Metal(Aluminum) Accumulator Piston
* TransGo Seperator Plate
* Hardened Pump Rings
* Sonnax 4th Gear "Super Hold" Dual Servo
* Wide sungear bushing
#36
12 Second Club
Originally Posted by SS Escalado
hey o3GMC where did you get your 65e and all of the parts? i am thinking about getting one of these especially if it can handle 400 rwhp.
#37
Originally Posted by O3GMC
FlowmasterMufflers
09-11-2015 03:32 PM
2005, 4l65, 4l65e, c6, failure, horsepower, limits, performance, powerglide, sitewwwls1techcom, tahoe, upgrade, wiring
