What makes it a 4L90E?
Old 12-04-2011 | 02:06 AM
1994Vmax's Avatar
Default What makes it a 4L90E?
Just as the title says. Is there actually any real hard part changes from the newest Duramax powered vans ( and probably even 6 liters) with the 4L90E versus the 4L80E from a 6 liter truck beneficial for strength? I am looking for a trans to use behind my 94's LQ9 and was wondering if anyone actually knows. Google came up with nothing other than a post of my own on another board from a while ago, lol. I am looking for something low mileage that I can add a shift kit and stall too and then forget about.
Old 12-04-2011 | 01:45 PM
Vince B's Avatar
4L90E? Are you sure your not talking about a 6 speed?
Old 12-04-2011 | 01:50 PM
nonnieselman's Avatar
Ive heard of a 4l85 but not a 90.
A 4L80e will be plenty for what your doin.
Old 12-04-2011 | 01:54 PM
1994Vmax's Avatar
Good god no, you can keep the 6L90E contraption, lol. 4L90E is what lives behind the Duramaxes in the vans because they don't use the Allison. Older models had a 4L85E in them as well. I imagine there is an internal difference between them and an 80E increasing it's torque rating.
Maybe people are screwing up and calling the 85E a 90E but it's what the 2010 and 2011 diesel van guys say they have.
85E's are not tough to come across and probably the route I will take. An 80E will be fine most likely, but my LQ9 is not staying a bolt on stock affair. Price difference is nill so I will buy the best I can get initially.
Old 12-04-2011 | 02:12 PM
1994Vmax's Avatar
Maybe there is no 4L90E and just the 85E. The 85 has a 5 gear planetary set in among other improvements over the 80E making it more appealing. I am hunting vans for transmissions as finding 2 wheel drive trucks up here is not easy in the wreckers. 85E it is!
Old 12-04-2011 | 02:45 PM
Vince B's Avatar
You do know this is what I do for a living right? I honestly have never heard of a 90E in the 20+yrs Ive been at this. Here is a thread that I posted some info in last week. However I did see a couple of comments about straight cut planets and that does not make a unit an 85 either. https://www.performancetrucks.net/fo...erence-492862/
Old 12-04-2011 | 02:52 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Chevrolet Performance Parts
Copy from above page.
24221098 - 4L85-E Four speed rear-wheel-drive, electronically controlled, automatic overdrive transmission with a torque converter clutch. GM has changed the part number on this transmission to 24227618. P/N 24227618 is a remanufactured transmission with a core charge. GM may bring back P/N 24221098, we are trying to get more information on this from them. We can only order P/N 24227618 at this time.
This is the best performance four speed automatic transmission that GM Performance Parts offers, rated for a maximum engine torque of 460 lb.-ft. This 2 wheel drive version of the 4L85E automatic transmission and includes torque converter. It is used in the current model GM Heavy Duty Trucks. Using a die cast aluminum case keeps the total transmission at only 255lb. The gear ratios are 1st - 2.482, 2nd - 1.482, 3rd - 1.000, 4th - 0.750, and reverse is 2.077. The converter size is 310mm (diameter of torque converter turbine), with maximum shift speeds at 5200 RPM for all gears.
Technical Note: This transmission has the conventional Chevrolet bolt pattern for attaching to engine. Use DEXIII fluid type.
4L85E gear ratios: 1st 2.482, 2nd 1.482, 3rd 1.000, 4th 0.750, Reverse 2.077.
Engine Range: 4.8L - 8.1L Gasoline, 6.5L Diesel (MN8)
Maximum Shift Speeds: 1-2 5200 rpm (MN8), 2-3 5200 rpm (MN8), 3-4 5200 rpm (MN8)
Maximum Engine Torque: 460 lb-ft (MN8)
Maximum Gearbox Torque: 885 lb-ft (MN8)
Converter Size: 300mm (MN8) (reference), Diameter of torque converter turbine.
Fluid Capacity (Approximate): Bottom Pan Removal 4.0L - 6.0L (4.2 qt - 6.3 qt)
Case Material: Die Cast Aluminum
Assembly Sites: Ypsilanti, MI
Technical Notes: Use with transmission controller P/N 12497316. (No core charge required on this transmission)
24221100 - 4L85-E Four speed rear-wheel-drive, electronically controlled, automatic overdrive transmission with a torque converter clutch. GM has changed the part number on this transmission to 24227619. P/N 24227619 is a remanufactured transmission with a core charge. GM may bring back P/N 24221098, we are trying to get more information on this from them. We can only order P/N 24227619 at this time.
This is the best performance four speed automatic transmission that GM Performance Parts offers and is rated for a maximum engine torque of 460 lb.-ft. This 4 wheel drive version of the 4L85E automatic transmission includes torque converter. It is used in the current model GM Heavy Duty Trucks. Using a die cast aluminum case keeps the total transmission at only 255lb. The gear ratios are 1st - 2.482, 2nd - 1.482, 3rd - 1.000, 4th - 0.750, and reverse is 2.077. The converter size is 310mm (diameter of torque converter turbine), with maximum shift speeds at 5200 RPM for all gears.
Old 12-04-2011 | 02:56 PM
Most of the 4L90E stuff I see is when people are actually talking about the 6L, but they typed it wrong.
Old 12-04-2011 | 03:00 PM
Vince B's Avatar
I'm pretty sure the performance version is built right here in the Chicago area.
Old 12-04-2011 | 03:28 PM
Coban's Avatar
GM has been putting the 6l90e with the Duramax vans in 2010 and 2011...
2009 and prior had 4l85e.
I guess the 6l90e is so good they can't even tell the difference....
