What rear suspension setup to use?
Old 04-27-2016 | 08:22 AM
1bad2k's Avatar
Originally Posted by thebwlife
No but maybe I should. Who makes them and what are the preferred brands?
I know for sure ride tech does if you are 2wd. Now if you're 4x4 pm atomic for his setup.
Old 04-27-2016 | 08:47 AM
2KRedSilverado's Avatar
I have Beltech 2508's and lost no turning radius. Back shocks I have a pair of Monroe's that rode perfect for me, I'll see if I can get the part number for ya.
Old 04-27-2016 | 08:48 AM
thebwlife's Avatar
Originally Posted by madmann26
Coming from someone who has changed his front suspension 3x now,
Get the McG spindles and BT 1in drop spring. It will ride damn near stock without the bumpsteer BS of the BT spindles. I have BT street shocks on all 4 corners.
For the rear, look at the DJM flip kit. It allows you to adjust the pinion angle without needing shims. For 5in in the rear, you would do a flip kit and a 1in lift shackle. Or you could leave it at 6in.
I would suggest doing the notch. Your choice on what you use but the key part is supporting the frame in front of the wheel and after the wheel so you don't bend/break the frame when you cut.
Its notched already. I'll defiantly look at your suggestions. Thanks again!
Old 04-27-2016 | 08:49 AM
thebwlife's Avatar
I'm 2wd. I'll check out ridetech.
04chevy2500
09-13-2016 11:37 AM
LJ93Z28GM
06-29-2016 08:12 PM
vipergtrdj
05-02-2016 09:46 PM
About20ninj45
04-21-2016 07:20 PM
Quick Reply: What rear suspension setup to use?
