What shift kit should I get?
Old 02-17-2006, 04:46 PM
Hunt&Fisherator
silver-mod-o's Avatar
mine only has about 30 on it too... its just extra insurance...
-the piston replaces the stock plastic one in the trans. the plastic one may fail when the tranny pressures are increased. the aluminum one wont. it will give you much faster shifts thus reducing wear on the friction parts... (bands, clutches)
Old 02-17-2006, 04:53 PM
Colby 04's Avatar
ohhhh, that's right. Do the HD2 install instructions show you how to install the accumulator piston?
Old 02-17-2006, 04:57 PM
Colby 04's Avatar
Get a hardened seperator plate anyway
Get this trans cooler
http://www.bulkpart.com/Merchant2/me...roduct_Count=4
I have it on mine and have towed with a 3K stall and it didnt overheat and it is always better to have too much then too little.
Is that tranny cooler practically a bolt in? You just take the lines loose from the radiator and convert to barbs for the cooler, then mount it?
Old 02-17-2006, 05:06 PM
Hunt&Fisherator
I dont know if the kit's instructions will have the piston instructions but I am sure the piston will have instructions with it... it should be pretty obvious once you get it apart to see where everything goes though.
Old 02-17-2006, 05:21 PM
Colby 04's Avatar
What about the .490 boost valve? Is it needed, does it come with the HD2 kit?
The list just keeps getting longer....
Old 02-17-2006, 11:01 PM
1badsilver's Avatar
I guess i'll get all this:
Transgo HD2 Kit
Hardened seperator plate
aluminum 1-2 shift accumulator piston
vette servo
Would the billet servo be better, since i can get everything so cheap on oregon transmission?
Anything else recommended?
Old 02-18-2006, 06:05 AM
Hunt&Fisherator
the billet servo is a little better but its also quite a bit of a price jump... thats the same parts list that I have with the 'vette servo... I think with all the other stuff the 'vette servo should be fine... OPT has some good prices huh... I will definitely buy from them again. They sent my stuff really quick too.
Old 02-18-2006, 04:26 PM
1badsilver's Avatar
That's what i'll get and i'll order from OPT. Thanks for the info guys
Old 02-18-2006, 04:29 PM
EXTREME's Avatar
HD2 w/hardened sep plate and servos like stated above!!
Old 02-18-2006, 05:16 PM
Hunt&Fisherator
I am sure there is someone out there that may be cheaper but someone from this site turned me onto OPT and I havent found them for cheaper anywhere... the HD2 kit is like 89 bucks and the sep plate is something like 16.... all their parts are good stuff.. just less expensive. I am sure they buy all their stuff in crazy bulk though so they can afford to sel it for less and still make something. everyone's gotta eat... LOL...
Quick Reply: What shift kit should I get?
