What shift kit should I get?
Old 02-18-2006, 05:26 PM
  #21
1badsilver's Avatar
I've heard nothing but good things about OPT, so i'm ordering through them as soon as i get a little more $$$
Old 02-18-2006, 06:17 PM
  #22
Colby 04's Avatar
I just ordered my stuff this afternoon from OPT
(I was going to buy from a member, but he wanted CC #, didn't feel comfortable giving my CC# out like that...)
parts list:
------HD2
------vette servo
------seperator plate
------1-2 aluminum accumulator
around $130 bucks shipped
Old 02-19-2006, 03:37 AM
  #23
Hunt&Fisherator
silver-mod-o's Avatar
thats exactly what I got... just dont forget to change your filter while you are at it... might at well and its cheap. What kind of fluid do you run in there??? I use B&M fluid but I am wanting to change and try something else.
Old 02-19-2006, 04:30 PM
  #24
getchusum99's Avatar
doesnt really matter the brand of fluid as much as when u change the fluid that matters, imo, i would get a big cooler and change it every 15,000.just my 2.
Old 02-20-2006, 12:31 PM
  #25
1badsilver's Avatar
What's involved when installing all of the parts?
Old 02-20-2006, 12:40 PM
  #26
Hunt&Fisherator
drop the pan take out the valve body and follow the instructions... you should be fine...just take your time and I dont know if its been said but have a little vaseline handy to keep the check ***** in place when you are messing with the valve body... I havent done a 60e yet but this is just a good rule of thumb for any auto tranny.
Old 02-21-2006, 02:04 PM
  #27
mjcotroneo's Avatar
i wouldnt advise a shift kit i havent read all of the post for yours but i wouldnt go with a shift kit. i had 3:73's and with my kinda drivin and a shift kit i flattened out those gears. weird i kno. then after a while my transmission went, valve body and 3rd and 4th gear burned up. the electronic transmissions are programmable, and you dont need a shift to make a 4l60e shift the way you want it to. this is wat i did on mine and it worked better than a shift kit if you ask me. i took the cap off to my soleniod there are two wire a C and a D wire. take one of the wires, whichever one is easiest to get to splice another wire to it thats long enough to go thru your floor and hook it to a toggle switch and mount where ever you want. flip it up and the transmission shifts firm, flip it down and the transmission goes bak to stock, accept for me i messed with mine a little bit. i torqued down my soleniod and then did the switch. i got it to where my truck will cherp goin into 3rd not a lot but for an ecsb thats pretty damn good if you ask me. i have the print outs somewhere of the solenoid if you want them i can email em to you.
Old 02-22-2006, 06:17 PM
  #28
1badsilver's Avatar
I already have a tune that firmed up the shifts, i just want them to be more consistent and the last thing i want to do is cut and splice wires that control my transmission. Just doesn't sound like a smart idea. I'll stick with Transgo.
Old 02-23-2006, 07:19 AM
  #29
ZR1 DREAMING's Avatar
Old 07-04-2006, 03:03 PM
  #30
Blown02Sierra's Avatar
Would replacing the lockup solenoid make the lockup hold better? And should the filter be replace while i'm in there?
Oobray
06-13-2022 03:38 AM
Blackrat48
08-16-2015 11:56 AM
lycominghunter
08-15-2015 12:26 PM
Ammadien
07-22-2015 08:50 PM
zaathur151
07-06-2015 10:57 PM
Quick Reply: What shift kit should I get?
