What size DR/slicks should I run
Old 03-22-2015 | 04:03 PM
xpolar1's Avatar
Default What size DR/slicks should I run
I am trying to decide what size slicks/DR to run on my truck. The truck has around 450hp with 3.73 gears. End goal is 1000ish hp with a 4 link. I think I am going to stick to a 10.5" wide tire, but the height is what is confusing me. Let me know what you think
Old 03-22-2015 | 08:16 PM
Atomic's Avatar
I have a gauge for that
Depends on what trap speed you think you will end up at, and 1/8th or 1/4 racing. You could probably get away with a 26" tire for 1/8th, but will want at least a 28 if not 30 for 1000hp in the 1/4
Old 03-22-2015 | 09:10 PM
xpolar1's Avatar
I was leaning towards either a 29.5/10.5, 31/10.5, or 31.5/12.5 depending what was suggested on here. I know the white rhino is running a 31.5/12.5 and he has a little more power than my end goals. My end goals is low 10s/high 9s in the 1/4
Old 03-22-2015 | 11:04 PM
George C....'s Avatar
Formerly ScreamingL
white rhino is also a chassis truck
29 or 30" will be fine your gears may change as well
Old 03-23-2015 | 01:24 PM
xpolar1's Avatar
And by chassis truck you mean? The gears will be changed when the rear end goes. Ford 9" is going in when that happens and will change the gearing to the optimal ratio
Old 03-24-2015 | 08:57 PM
xpolar1's Avatar
If by chassis truck, you mean tube chassis. I would highly recommend you look at his truck more closely. His truck uses stock frame rails that are boxed in. The only thing that helps his truck hook is the added reinforcement by the 12pt cage
Old 03-24-2015 | 10:35 PM
Formerly ScreamingL
i saw the complete build online of the truck and its chassis
Old 03-25-2015 | 09:12 PM
xpolar1's Avatar
So then what do you mean by chassis truck then?
stealthperf
34
02-14-2016 12:35 PM
FlowmasterMufflers
07-30-2015 06:03 PM
silver-mod-o
07-27-2015 06:24 PM
kdw8888
07-09-2015 11:52 PM
jrplz
07-09-2015 01:07 AM
