What size drill bit's did your Transgo 4l80e-hd2 bring?d2 kit
Old 08-14-2011 | 12:21 PM
phasemaster1's Avatar
Default What size drill bit's did your Transgo 4l80e-hd2 bring?d2 kit
The kit I got from summit has .085,.117,.180.
Im assuming the Separator plate has the holes already at the .076 softer shift size. Where did you get drills in the .090-.095 sizes? What does the last letter in the kit mean? Mine is 4l80E-HD2-D
Old 08-14-2011 | 12:28 PM
swift700's Avatar
If you have a drill bit set and a micrometer you can find a bit that works. If I remember correctly, Transgo gives three recommendations for soft, medium and firm shifts and provides the bit dimensions. In reality you can drill to any size in between the smallest and biggest recommended size. I don't remember the exact size but I found a bit that was in between the medium and firm size and it turned out perfect to me.
Old 08-14-2011 | 12:31 PM
swift700's Avatar
If you have a drill bit set an a micrometer, you can find a bit that works. If I remember correctly, Transgo gives three recommendations for soft, medium and firm shifts and provides the bit dimensions. In reality you can drill to any size in between the smallest and biggest recommended size. I don't remember the exact size but I found a bit that was in between the medium and firm size and it turned out perfect to me.
Old 08-14-2011 | 07:42 PM
brandon6.0's Avatar
i had this problem my self. I found out that a 3/32 bit is the same as a .094 drill bit. Hope this helps. I heard if u want to change up to get exactly what u want thin u will need to get a 150 piece drill bit set. It would have all of them. Hope this helps.
Old 08-14-2011 | 09:58 PM
Thanks guys going to see what I find at work tomorrow. Id like to get this right the first time. Getting back in there while its in the truck has to be a pain in the ***.
Old 08-16-2011 | 11:05 PM
Bought a cheap drill set from harbour freight $20. I ended up using .080,.093,.085
Old 10-27-2011 | 08:20 PM
Beatdown Z's Avatar
Laid Back
Get it done and back on the road?
How do you like your shifts?
Old 10-27-2011 | 08:52 PM
Jrluz14's Avatar
If anyone ever needs any size drill I'll be glad to ship them in an envelope as long as you ship them back. I have every size at my shop.
FlowmasterMufflers
07-30-2015 06:03 PM
Ammadien
07-22-2015 09:50 PM
HIDEXTRA
07-21-2015 06:43 PM
jrplz
07-09-2015 01:07 AM
zaathur151
07-06-2015 11:57 PM
Quick Reply: What size drill bit's did your Transgo 4l80e-hd2 bring?d2 kit
