What size is my rear end?
Old 02-03-2005, 10:15 AM
14 Second Truck Club
It would be an 8.6, not an 8.5. The only difference is the size of the carrier bearings, the ring gears interchange. In 99 they changed the ID and OD of the carrier bearings. The internal parts of the case, and the case itself are different for the stock parts. If you were to buy an Eaton it would be the same for 8.5/8.6 because they upgraded the bearing size on their units years ago, which is why they needed a special bearing for 98-older vehicles. They are both 30 spline, unless the 8.5 is 88 and older, which are 28.
Old 02-03-2005, 08:05 PM
derek_silvy's Avatar
Thanks for the info....
Do you have any idea which bearings (as in a part #) that I will need?
Old 02-03-2005, 08:42 PM
Off the top of my head I think it is 2- LM603012 and 2- LM603049. I will try to double check that tommorow.
Old 02-03-2005, 09:31 PM
Thank you very much!
TAPyvehc93
07-23-2017 10:54 PM
pjb1972
09-17-2015 02:06 PM
vipergtrdj
08-06-2015 10:19 PM
shupe
08-05-2015 06:45 PM
Ketis
07-23-2015 12:37 PM
Quick Reply: What size is my rear end?
