What will it take to add a factory oil cooler to my truck? Are the factory ones good?
Old 09-13-2005 | 09:49 PM
hirdlej's Avatar
Default What will it take to add a factory oil cooler to my truck? Are the factory ones good?
Another question running through my mind tonight, me being the gearhead I am I never leave the stock cooling system alone on any new trucks I have. I will be eventually putting a bigger radiator in than what I currently have on the truck, but what I would really like to know is how does the factory oil cooler hookup? Do the oil cooler lines run through the radiator or are they on their own separate mini radiator? Also, does anyone have the GM PN#'s for everything I'll need? Or does anyone have the entire setup off a junk motor they may have pulled?
Thanks,
Joe
Old 09-14-2005 | 07:15 AM
tdrumm's Avatar
The stock oil cooler runs through the radiator. Radiator barn has the 34" core radiator with oil cooler for around $350.
From there you'll need the lines from the engine to the radiator and the part bolts onto the block that the oil filter screws onto. Sorry, I don't have part numbers.
Old 09-14-2005 | 02:53 PM
hirdlej's Avatar
Screw it, sounds like too much dilly-dallying. I'm going to push this one aside and get started on the cam swap next
Old 09-14-2005 | 04:51 PM
I added a B&M cooler for my engine oil and I bought the oil cooler adapter from LG motorsports. Took me about a half a day to install the engine oil cooler and redo the tranny cooler.
Noah Burns
09-07-2015 06:50 PM
Suburban2500
07-19-2015 05:50 PM
black6spdz
07-16-2015 02:32 AM
Suburban2500
07-13-2015 10:57 AM
skylark
13
07-11-2015 01:54 PM
