what would cause a transmission to miss 2nd at WOT
Old 11-18-2014 | 07:46 PM
  #21
BlackGMC's Avatar
Resident Retard
Sooooo is it ready togo?
Old 11-18-2014 | 07:54 PM
  #22
TXsilverado's Avatar
is this enough for someone to calculate converter slip? i was trying to get it up to 7k RPM in 3rd but traffic was coming up quick in a 55mph zone. 275/60-15 drag radial pro with 4.10 gears and 65e.
Old 11-19-2014 | 02:17 AM
  #23
bigfatls6's Avatar
Get a tighter converter and make more MPH or looser and 60ft better lol..
Old 11-19-2014 | 05:09 AM
  #24
03sierraslt's Avatar
To calculate slip you need engine rpm and trans input speed.
Old 11-19-2014 | 05:52 AM
  #25
TIM Z's Avatar
11 sec. Truck Mod
When I ran the 60-65-70e's mine would blow thru second gear way to fast , it ended up burning up my 3-4 clutches every time . Prob should have tried to play with the shift delay myself .
Speaking of what Roger and Pat touched on , I'm wondering your steels might need a small hole in them to help prevent that centrifugal apply or if those clutches have grooves to give the fluid a path to exit . I'm sure Vince used all the tricks , these 60s are just a PITA sometimes with big power , plus you spin yours damn fast . That's got to be a fun truck to drive .
Old 11-19-2014 | 07:19 PM
  #26
Originally Posted by dubwise
You are running a carb along w/TPS sensor, right?
A shot in the dark, but have you verified the TPS is adjusted right? I'm not familiar with how the TCI unit works, but maybe it could be a combo of the TCI mph/rpm shift points + mis-adjusted TPS causing it to somehow skip 2nd gear?
yes, carb with TPS. at the WOT value that you determine, it only shifts by RPM. at part throttle it has to meet your predetermined mph to upshift/downshift. everything is set now. with a WOT minimum upshift value of 0 at WOT, the solenoid A literally got zero time to respond. I guess the controller just defaulted to releasing to 3rd gear if solenoid A does not respond. I'm making guesses at this point. giving it .5 seconds for 2nd gear to react made it work. I could probably come down on that value now that I know what it does, but i'll just bring my shift rpm down to 6900 so it will actually shift at 7,300.
I think so
I think I can possibly gain in both areas by going smaller. no need for a 6,000 converter on my street ap. I'm flashing WAY past my peak torque.
it's all working good in the hood now. Vince put every trick in the book on this one. if it can be done, he did it.
Old 11-19-2014 | 08:20 PM
  #27
AKlowriderZ71's Avatar
11 Second Hall Moniter
I think he mods the frictions with fish scales, and the valve body with the gills.
Old 11-20-2014 | 12:06 AM
  #28
this explains why why my pan gasket looked like it was carved with a filet knife.
blownss27
08-14-2020 09:27 AM
Texas5.3_1251
03-05-2016 09:10 PM
FlyingLow
11-24-2015 11:05 AM
Go5.3tt06
09-14-2015 03:11 PM
