What are y'all guys doing to upgrade the tranny?
my friend tuned with me last wk and while we were making some wot runs and with the stock cooler the trans temp never got above like 174*. Granted this was in 76* heat but do you guys think there is any need to upgrade the cooler?
Corvette intermediate servo
Billet 4th apply servo
Double cage 29 element forward sprag
Alto carbon oversized 2/4 power band w/ reinforced anchor
New input drum/housing
Rebestos blue 3/4 clutches and steels
Rebestos blue overrun clutches and Koleen steels
Beast reaction shell
GM front / rear 5 planetary carriers (if you dont already have them)
Thrust bearing kit
Sonnax boost valve
Billet forward accumulator
Billet 1-2 accumulator
EPC Solenoid
Superier valve body shift correction kit
4L65-E overhaul kit(gaskets,seals, ect)
Updated valve body seperator plate
Billet 300mm output shaft
Billet input shaft
Billet input drum sleeve & piston
RPM high-rev spring kit
Longer servo pin then grind tip for clearance
Tru Cool 40k BTU Trans cooler
And im running a billet 3400 TCS converter with this ^^^
Thrust bearing kit
Sonnax boost valve
EPC Solenoid
Billet input shaft
lxcoupe
07-21-2015 02:12 AM
