what year 4l80e
Old 08-29-2009 | 05:02 PM
SLOXCAB's Avatar
Default what year 4l80e
what year 4l80 will fit in my 04? can i use the 1990s tranny cause those are pretty easy to find?
Old 08-29-2009 | 05:05 PM
stevenc's Avatar
I remember reading that the earlier ones didnt have mounting provisions for the shift cable or something.
Old 08-29-2009 | 05:09 PM
SLOXCAB's Avatar
so then i need like 99 and up
Old 08-30-2009 | 02:20 AM
James B.'s Avatar
A 1997 and up has the right mounting for the linkage and the return line in the back. It doesn't have the top center hole in the bell. If you want that and a bunch of improved internals, find a 1999+.
2001+ have a newer designed roller clutch with rollers that supposedly don't skew. (I've shredded one of those so-called improved roller clutches, the older roller clutches have larger diameter rollers. Running the old design now, myself.)
Old 11-15-2009 | 04:43 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Bump for my question...
I currently run a 4L80E in my Tahoe, pretty sure its a 2005 trans. I am looking to swap in a 2008 4L80E. Anybody see a problem with that? Are all the wiring connections and physical dimensions the same? Will my Vig converter slide right in as well?
Thanks!
Old 11-15-2009 | 05:27 PM
SLOXCAB's Avatar
Sell me that 05 4l80e
Old 11-15-2009 | 05:39 PM
1SlowHoe's Avatar
Im probably gonna keep it for a spare. Its built with good stuff inside.
Old 11-15-2009 | 07:56 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I Found one 01 up with the top bolt hole You want the Number???
Old 11-15-2009 | 09:28 PM
FLT's Avatar
FLT
FormerVendor
Thanks!
Have not seen you on here in a while and you come on here with an attitude!
JFWY Good to see your still alive! Yes the 08 will work for you. Vince
Old 11-15-2009 | 10:09 PM
1SlowHoe's Avatar
Hey Vince! I didn’t scroll down at first and I was re-reading my post thinking..Attitude? Where did he get that from lol.
What I really want to do is drop the separator plate and see if the 1-2 shift fluid hole or whatever you may call it isn’t drilled twice what it’s supposed to be. I want to replace it with a new plate drilled to the smallest diameter. The 1-2 is just too hard. I found an 08 trans and was thinking I could just swap them out and sell mine to a track truck owner, the shift is bad *** at WOT but it’s just as hard at 9mph lol Vince sell me a plate already prepped!
Bluecollar Hotrods
06-12-2024 12:37 AM
Oobray
06-13-2022 04:38 AM
XL7
05-05-2022 02:48 PM
GXPJAY
02-13-2022 09:15 AM
Zacholcomb
09-03-2015 07:14 PM
Quick Reply: what year 4l80e
