What year 4l80e do I have?
Old 03-21-2014, 05:20 PM
03sierraslt's Avatar
The 80e that has the rear lube fitting uses a different fitting. If you don't use the longer rear fitting you can burn it up. Is yours a 97-99? If so then you have the newer lube circuit with no top bolt hole.
Old 03-21-2014, 06:21 PM
greasemykey's Avatar
it had no top hole but the factory fitting i took out had about 3/4 inch tube after the threads.
Old 03-21-2014, 06:23 PM
So it had a fitting in the front and rear instead of one on top of the other like a 60e does, Right?
Old 03-21-2014, 06:34 PM
yeah had a rear fitting
Old 03-21-2014, 06:37 PM
Yours is a 97,98 or 99 then. Were there any tags on it or anything? Metal tag on right side or tag like pictured above?
Old 03-21-2014, 06:43 PM
**** did jake send me the wrong one then? i told him i had a 2000 silverado 1500
Old 03-21-2014, 07:02 PM
It will be fine, places use various cores. Some builders prefer certain year cores.
Old 03-21-2014, 07:04 PM
ok everything bolted up great. just waiting to do my cooler lines and segment swap. cant get my HP tuners to read anything from my pcm at this point.
Old 03-23-2014, 05:44 PM
hsiriyob's Avatar
I think the first number on the 80e is the year. your getting there dude!
Bluecollar Hotrods
06-11-2024 11:37 PM
Oobray
06-13-2022 03:38 AM
XL7
05-05-2022 01:48 PM
GXPJAY
02-13-2022 08:15 AM
Zacholcomb
09-03-2015 06:14 PM
Quick Reply: What year 4l80e do I have?
