wheel hop
wheel hop
i have a 01 2500hd 496ci Allison 4x4 crew cab, the problem that i am having is that when i drive my truck in the sand, if i am in a dead stop and try to drive out of the sand the rear tires will hop and shake up the truck. i almost got the truck stuck in the sand because of it. its wierd because i can do a burnout on pavement and both tires spin nicely. i just want some ideas or recommendations on how i can fix it. thanks.
i have thought about ladder bars, but i wanted to ask you guys first then go from there. if that will help the hoppin', then i will look into purchasing a set. thanks.
AIR DOWN THE TIRES! that and use alittle less throtle. i have seen numerous full sizes stuck in the dunes.due to the wieght factor. you just gotta be carefull about the way you are driving it.
George C....
09-11-2015 04:45 PM
