Wheel hop
Old 05-05-2010 | 08:45 PM
BigHate's Avatar
Default Wheel hop
got a 00' RCSB. installed a DJM 4-6 kit 2 years ago. just installed my LQ-9 6 mos ago and when the tires break loose it has horrible wheel hop. the only thing i can think of my pinion angle is definitley off. thanks for any help.
Old 05-05-2010 | 09:05 PM
Mangled03gmc's Avatar
Baltimore Whore
Pinion could be off, with that much of a drop, but a set of spring clamps( cheap way) or cal-trac bars will stop the problem..
Old 05-05-2010 | 10:06 PM
Daryn's Avatar
Formerly darynC-10/23/10
get a set of adjustable shocks
Old 05-06-2010 | 07:37 AM
Raffman's Avatar
Take a look at your pass side rear shock. When I had that kit on mine it was breaking that lower mount. Did it a bunch of times, that's when the wheel hop would show up!
Old 05-06-2010 | 11:14 AM
BigHate's Avatar
yeah it came with the shock relocator bracket and it busted the shock mounts off the axle. i welded the stock mounts back to the axle tube and then the bracket to the mounts. its pretty ugly but it is secure.
Old 02-07-2011 | 02:57 AM
What do you mean by spring clamps?
sprayed99
09-21-2015 04:47 PM
Glenn98ZM6
09-18-2015 07:31 PM
George C....
09-11-2015 04:45 PM
dselby25
09-11-2015 05:03 AM
the owl
09-04-2015 04:09 PM
Quick Reply: Wheel hop
