Wheel and Tire fitment??? Nitto 305/55r20 20x10
I need some help guys. I got a 2003 2500 HD 4x4 6.0L and want to fit Nitto 305/55r20 tires, that are 33"x12.5". My wheels that I bought are Weld Velocity 8, they are 20" x 10" w/6" backspacing(-25mm) and 4" lip. Can these fit on a stock hieght truck or will a 3" body lift work?
How detail is it to install a 3" body lift on these truck, also how much should I expect to pay if someone installs the body lift for me?
Thanks,
Chance
Thanks,
Chance
what a rush!
Thanks,
Chance
Thanks,
Chance
I would think that 6" bs is to much my 4 5/8" bs is rubbing a bit under full turn. I guess the 12.5" wide tires could be the reason for that as well; but 6" bs would put the tire closer to the frame rail.
what a rush!
Actually, on HD's, the farther you can tuck a wheel in the wheel-well the larger tire you'll be able to run at a stock height. HD's have the wider front track width and that's what causes all the clearance issues. 4 5/8 is standard off road BS and should still work just fine.
His 6" BS will work too, but he'll have to decide which compensatory method he wants to use.
Most Common:
T-bar crank
Bumper Trim
Bumper spacers (washers & longer bolts)
Body Lift
Suspension Lift
He may need one or two of these to get that wide of tire to fit.
My personal feeling is that with a T-bar crank(leveling) and a bumper trim with 6" BS he will be just fine with a 305/55-20.
Originally Posted by moregrip
I have 32" (305/50-20's) tires with 6.5" BS. Had to trim the lower front bumper a bit, that's all. Could have cranked the t-bars, chose not to.
Most Common:
T-bar crank
Bumper Trim
Body Lift
Suspension Lift
Most Common:
T-bar crank
Bumper Trim
Body Lift
Suspension Lift
Chance
what a rush!
What all is involved in doing the bumper spacers? Also did you trim the metal/chrome bumber or just the valance? I can go with the 305/50R20 nitto grapplers if they will fit w/o having to do a body or suspension lift. I can crank the T bars as well.
Chance
Chance
I honestly don't think you'll have to do more than that if you crank the T-bars for the 305/55-20.
If you choose the 305/50-20's then all you'll need to do is trim the valance.
But some HD's don't need it.
hope this helps
what a rush!
OK Guys, offset is -25. So I guess that is about 5" or so backspacing and offset. Do you think I will have a problem with these??
