Wheel wobble! Help/ideas/etc.???
Hey guys. I just had my inter. med. steering shaft replaced about 2 months at the dealer and they said my tires were looking pretty bad so I dropped a good amount on some Goodyear silent armor 20/275/55's and they are awesome! HOWEVER, I now have a major problem in the form of a horrible and annoying wobble at 65 - 75 mph! I've been back to the Goodyear dealer 3 times for new balancing and stuff and they said they are as prefect as they can get them.
I difinitely think there is now something else going on! I'm taking it to the dealer this Wed. to have them look it over. I know my shocks are starting to really feel 'soft' (feeling ever little bump or crack) and I'm about to replace them. I did also 'upgrade' my tie rod ends, idler arm and ball joints about a year ago with MOOG replacements. I also have upgraded sway bars front and rear...
The truck has just now got 40k miles
So I'm VERY much wanting to get rid of this 'WOBBLE' too and the Goodyear guys feel horrible too since they put these new badass tires on and now I'm having problems...
Also there is a clicking, tapping 'electiric' snapping noise coming out from under the truck somewhere. Hard to pin point. Just started noticing it too and was going to point it out to the dealer too...
I'm going to ask the dealer to check the following:
1. Tie rods
2. Hub assy.
3. Steering arm(s)
4. Bearings
5. Bad tire(s) Goodyear says no
6. Bad rim(s) Goodyear says no
7. U-joints
8. Idler arm
9. Drivetrain
Anything else anyone can think of??
1. Tie rods
2. Hub assy.
3. Steering arm(s)
4. Bearings
7. U-joints
8. Idler arm
9. Drivetrain
PT's Slowest Truck
I'm still leaning towards a tire issue...I was going to say, as HirdleJ mentioned, that I've seen alot of problems with GoodYear tires, but I didn't want to burst your bubble. The roadforce balance puts force against the tire as it spins to simulate the force of the road. Sometimes a tire has to be turned 180* or 90* on the wheel to balance out. The balancer will display if the roadforce variation is too great and cannot be balanced.
Since the tire store said "as perfect as we can get them", I'm weary of if the tires can be balanced or not...
i had the same problem at about 45-50mph and i thought my balance was off..but i took to the local shop and they said it was my inner tie rods. Replaced those and it fixed the problem. I didnt know it until i posted asking if other people have had to change them and everyone said It is very common for people to have to change the inner tie rods in there trucks after about 40k miles.
Undoubtedly a tire issue...I'd bet a cup of coffee on it. You went in with no vibration issues, bought new tires, and now you have vibration issues. "As good as they can get them" isn't good enough, and this is common on 18" and greater wheels & tires. I'd recommend a Road Force balance on a Hunter machine. If your shop doesn't have one, ask them to pay for the service elsewhere. Or...
There are some alternatives you can try. First, move the backs to the front (one at a time) to try to isolate the issue. Second, have 'em do a 180 on the fronts to see if they balance out better.
Tires are subjective, but I have to agree with the sentiment on Goodyears. If you like 'em...great, but IMO there are just too many other...better...tires out there. Good luck with everything.
