When to start building tranny?
Old 01-03-2008, 02:01 PM
KevinF56's Avatar
get a transmission fluid cooler as well. doesn't "strengthen" the trans, but it keeps the fluid temps down which increases longevity.
Old 01-03-2008, 03:10 PM
Blitanicle99's Avatar
It has the towing package with the big tranny cooler already on it.
Old 01-03-2008, 03:19 PM
KevinF56's Avatar
that cooler isn't that big... i'd upgrade it to a larger unit, something in the 24,000 GVW range or bigger.
Old 01-03-2008, 03:20 PM
truckmann's Avatar
Old 01-03-2008, 03:33 PM
ZZebes's Avatar
thats not a cooler
this is a cooler
you know your tranny cooler is big enough when it's all you see through the grill
Old 01-03-2008, 04:11 PM
Would one from Napa, the heavy duty one be enough?
Old 01-03-2008, 06:15 PM
Mark Johnson's Avatar
And by all means- put a shift kit in there while you're at it...........
Old 01-03-2008, 08:14 PM
FLT
FormerVendor
FLT's Avatar
Originally Posted by ZZebes
David I think I have now voided your warrenty for the 10th time!! Keep up the good work! Vince
Old 01-03-2008, 09:11 PM
SS_bnoon_SS's Avatar
Originally Posted by jknox
Not even close. They won't even do stock hp levels reliably - that's why they have torque management in the first place.
But they are tunable. Put the 'vette servo in and have your tuner firm up the line pressures a bit. With a high-mileage trans I'd have him pull no more than 50% of the torque management out. I know others will say that you can pull all of it out if you do those two things but I wouldn't for a daily driver.
This is how I'm running and it's how it's staying until I get things to where I can get FLT to build a unit for me.
Agreed. I'm running maybe 400 horsepower with my mods and mine just bit the big one at 60,660 miles. I ran it for a while with all TQ management out from a PCMForLess tune, then when I got HP Tuners I put 20% back in and it still died in less than 2 year that I've had it. Build the trans before you pull to much out at all on more than double the mileage.
Old 01-03-2008, 11:03 PM
Alrighty, I guess my plan now is to go ahead and order the corvette servos and get another transmission cooler. Easy install if i take off the grille?
And again, would a heavy duty one from Napa do the job? Or should I be looking at Summit Racing..?
Quick Reply: When to start building tranny?
