who knows where to get larger inner bearing for pinion...
I remember somewhere reading about a kit or just a inner bearing that would just slide on the pinion to check pinion depth. That was just for mock up purpose so you wouldnt have to press the new bearing and find out you needed add a shim. Where can I buy that. Thanks
Get yourself an old bearing and take a dremel to it.. remove enough material from the ID so that the bearing will slide on and off the pinion freely..
lukn4trbl355
10-21-2015 11:19 PM
