Who makes a nice drive shaft loop?
#31
The purpose of the driveshaft loop which is 6" from the front yoke is so your driveshaft doesnt snap the ujoints from the rear of the trans and doesnt pole vault the car/truck. a driveshaft loop is not goign to prevent shrapnel from flying places
#32
Hunt&Fisherator
re-think the pole-vaul theory... have you seen it happen??? sure, it has before... but in most cases it just slides across the pavement. Thats not the sole purpose of the loop...
#33
That was why I asked ZZebes if that was his opinion he stated or factual. Because I haven't heard you need a front DS loop ever. NHRA doesn't give a **** if you **** your under carrige up, they want to prevent serious injury to yourself and others.
#36
it will keep the majority of the carnage under the vehicle... the broken shaft flopping around causes more damage than the drivashaft itself breaking most of the time...
#37
Now, I'm going to have to research info on a DS loop for the front DS... hopefully it's not required. ZZebes, did they tell you that you weren't allowed to run anymore? I wonder if I'll need one to run at the shootout
#38
Sweet thanks! That's exactly what I wanted to see!! I was thinking about doing exactly that on my torsion bar as well.
#39
Hunt&Fisherator
yes i seen a driveshaft cause a pole vault. a driveshaft isnt going to slid across at first its going to dig into the ground and cause major issues. NHRA/IHRA dont give 2 ***** about the undercarriage of a car. they care if the car flips or even causes it to go into hte next lane and take out the next vehicle. sole purpose is pole vault...then there are the other advantages of having one
whatever... mythbusters did it LOL... its not likely for a thin piece of aluminum/steel to launch a 4500+ # vehicle end over end... bottom line... it will probably crinkle up and bend first... I know its not likely... bottom line.
#40
yeah, I figured you had by the way you were talking
