Will a high stall torque converter bring back my lope?
Old 10-27-2008 | 05:34 PM
00ChevyScott's Avatar
Wearin' da big hat
Default Will a high stall torque converter bring back my lope?
My truck lopes pretty decent in park or neutral, but as soon as I put it in drive, it sounds like the trucks idle speed jumps up to like 850 and has no lope at all. I have checked in the tune and the idle speed is around 700-750 in park, and in gear. I have also checked idle rpms/in gear rpms with efi live in logs. I'm wondering if the stock torque converter is putting some drag on the motor causing it not to lope at all. Will say a 9.5" 3200 stall take that pressure off the motor while its in gear and let it lope in gear too?
Old 10-27-2008 | 05:38 PM
Mangled03gmc's Avatar
Baltimore Whore
Yes, you are pulling on the stock verter. Once you get a higher stall it will pull on it but will give you that lope back..
John
Old 10-27-2008 | 05:39 PM
Wearin' da big hat
Good, thats what I was thinking, but wasn't exactly sure.
I hate pulling up to a light and all i hear is BAWWWWWWWW, instead of blub blub lub blub lub lub blub.
my cam impression
Old 10-27-2008 | 05:41 PM
Baltimore Whore
Sweet but you need to listen to my 42 lber impress.. Here goes, (you need them, squirt squirt squirt)
hahaha
John
Old 10-27-2008 | 05:42 PM
Wearin' da big hat
hahaha
John
hmm idk if they'll go well with my cam then
blub squirt lub blub squirt squirt blub lub lub
sounds like you're banging a fat chick
Old 10-27-2008 | 05:44 PM
Baltimore Whore
No only after they try to sit up
John
LCHEE
10-24-2020 05:10 PM
TAPyvehc93
07-23-2017 11:54 PM
BennyB
08-01-2015 09:48 AM
KyleW707
07-29-2015 09:17 AM
JordanH
07-14-2015 04:46 PM
