Will JB Weld fix this?
Old 02-13-2010, 11:03 AM
  #41
james8997's Avatar
yea there pretty sweet. iv always bolted the transfercase up 1st, than stab the tranny. iv down it both ways and its sooo much easier putting the t-case on 1st
Old 02-13-2010, 06:23 PM
  #42
I have a gauge for that
Atomic's Avatar
Any advice on how to get those top 2 bolts to the trans? I cant get an angle with my socket and my wrench is too long
And where does that random breather hose attach thats just hanging around?
Old 02-13-2010, 06:25 PM
  #43
GMCtrk's Avatar
Best one Ive heard on here is to go from behind the intake manifold.
Old 02-13-2010, 06:30 PM
  #44
Atomic's Avatar
Oh ok so its more of a drain tube thing, I thought it was suppose to attach to the tcase but I couldnt find anywhere. Makes sense.
How about those bolts?
Old 02-13-2010, 06:35 PM
  #45
james8997's Avatar
yea, use your 9/16 gearwrench and go from the top. the hose your talkin about, IIRC, is a vent line that bolts to one the the tranny-to-engine bolts. there should have been a nut holding it on
Old 02-13-2010, 06:42 PM
  #46
Atomic's Avatar
My wrench is too long to fit between the tcase and body to turn it at all, thats the problem.
Old 02-13-2010, 06:47 PM
  #47
1Bear's Avatar
I think the multiple questions are causing a little of confusion (not your fault), but you were right with your 1st thought, it is a vent line from the transfer-case. The hose nipple is located on the front half of the case, up and above the front driveshaft.
As far as the bolts are concerned, I was able to access them with a "shorty" combination wrench.
Old 02-13-2010, 06:49 PM
  #48
james8997's Avatar
ooo, the transfer case bolts. mmmmmm
IIRC i used a racthet with a swivel head, its very tricky.
thats why i always put the transfer case and transmission together before stabbing them in the truck
Old 02-13-2010, 06:50 PM
  #49
james8997's Avatar
do you have stubby wrench?
Old 02-13-2010, 08:48 PM
  #50
Atomic's Avatar
I finally got it with some creative use of socket extensions and wiggling around.
One of the trans mount bolts wont go in without a fight, im afraid im cross-threading it but the other one went it easy and this one starts fighting a few turns after it catches.
Quick Reply: Will JB Weld fix this?
