will these tire fit on a 9" rim
295/45/18 Nitto 555 Or Toyo Proxy S/t Is A Sweet Tire. Ill Get A Pic Of My Truck Before With The Toyos On It Just Leveled Out In The Back In The Morning..NEVERMIND JUST SAW ITS A 4WD GET 305/60/18 NITTO TERRA GRAPPLER
The 10mm is your offset, which gives you a backspace of 5.39 in. on a 9" wheel.
The combination will stick out about an inch past the fenders, you might have some rubbing in the front. And if you bring the rear down 2", you possibly could have some issues there as well.
But, then again, I don't have a 4wd.
Edit:
moregrip has some 305's on his truck: https://ls1tech.com/forums/showthread.php?t=249496
I'm not sure what his backspace is, and he has 20's and his HD truck sits a little higher that a normal 4wd I believe. But you get the idea.
Edit:
his are almost an 1" taller than the ones i'm looking at. and parish had his truck lower with his stock tires and they are just a hair taller than the one i'm looking at. but i know mine are wide and the back spacing might make them rub. i think they'll be alright. (i hope lol)
Corvette454l88
09-01-2016 01:24 AM
gcsd3742
07-06-2015 05:22 PM
