At wits end with my truck.
Old 10-31-2015, 06:23 PM
BluLS1's Avatar
Well back to square one, I drove it withe the o/p unhooked and it made no difference on my original problem but the open reference code hasn't come back yet
Old 10-31-2015, 07:59 PM
Wolftrk99's Avatar
Plugging the opsu in shouldnt cause difference in map voltage.... I would need to find a wiring diagram to find whats common between them.... What is your map sensor reading vs the BARO pid (inHG) key on engine off??? They should be the same check them against barometric pressure in your area
Old 10-31-2015, 08:19 PM
BluLS1's Avatar
Well the 5v ref for both sensors are on the same circuit along with one more i think. so i can imagine if voltage was less that what it should be it would effect the MAP signals to the ecm. But my problem hasn't occurred again so it was either that, maybe the ecm had to relearn the correct paramiters for the MAP? I also thought maybe my problem was torque converter shudder so I put a also all amount of shutter fix in the trans.
Old 10-31-2015, 09:17 PM
Wolftrk99's Avatar
Interesting may have been the shudder.... Glad it seems to be fixed!!! post updates if returns!!!
Dawas
09-20-2015 12:00 PM
Shotguntommy
09-15-2015 05:24 AM
kalikid06
09-13-2015 05:48 PM
dselby25
09-11-2015 05:03 AM
sTNT971
09-11-2015 02:38 AM
Quick Reply: At wits end with my truck.
